CDT Audio MA-1502 2-Channel Amplifier
1 available
New, slight cosmetic flaws
Class AB design
Features:
Technical specs and contents
Dimensions
$250 shipped to the lower 48 states
Worldwide shipping is available. PM me for a quote.
Get 2 MA line amplifiers for $425 shipped.
Buy 3 MA line amplifiers, the 4ch, the 2ch, and the monoblock, all for $600 shipped.
All 3 models have the exact same physical dimensions. This makes your system layout symmetrical and easy to design.
1 available
Class AB design
Features:
- MOSFET power supply
- Plated brass set screw terminals
- 12 dB/octave crossovers
- variable high pass crossover (30 Hz - 500 Hz)
- variable low pass crossover (30 Hz - 500 Hz)
- Variable 0 dB to 12 dB bass EQ at 45 Hz
- 5 Way Protections
- Daisy chain through output RCA
- Power and protection LED
- 2 ohm stable
- Soft start/mute circuit
- Power Output:
- RMS @ 4 Ohm: 100WX2Ch
- RMS @ 2 Ohm: 150WX2ch
- RMS @ 4 Ohm 300WX1 mono bridged
- S/N Ratio: >95dB
- THD: 0.05%
- Channel separation: >50dB
- Input sensitivity: 0.2V-6V
- Input impedance: 20KOhm
- Slew rate: 10V/msec
- Damping factor: >100 At 4 Ohm
- Fuse rating: 40A
Dimensions
- Width: 139.5mm
- Height: 46.7 mm
- Length: 220. mm
