CDT Audio HD-M6 Midbass Woofers
1 pair
NIB
Superior Audiophile extended bass mid-woofer
I recommend using these with the QEX 10" or 12" subwoofers on the low end and any of the 2" mid/tweeters, 3" mid-woofers or 4" mid-woofers. Pairing these with 1" tweeters is not ideal.
The HD-M6 6.7” Enhanced Mid-Bass (cast frame) woofer has a slightly more massive voice coil than typical bass/midrange and leans toward the bass in the sound compared to the classic type woofer. The upper midrange is mellower than the standard type 6.5” mid-woofer designs.
These fabulously smooth, mixed fiberglass and fabric black-coned beauties extract all the music and add no coloration to the sound. From rap to rock to smooth jazz they are on top, and the rendering of serious classical profundities is also exquisite. Utilizing a rubber edge and soft polymer dust-cap these drivers create and absorb vibratory waves with astonishing control.
A magnetic system utilizing a shorting ring above the pole piece lowers modulation distortion to new lows. The Fs of 52Hz gives marvelous extension in compact situations. The HD-M6 has a superior smooth response imaginable from a larger speaker. You lose nothing in smoothness by going up to this 6.7-inch speaker. With its extended mid-bass punch, its size assures the sound has the authority audiophiles crave.
Technical specs and contents:
$159 shipped to the lower 48 states.
We can add 2" mid/tweeters or 3" or 4" mids to your order. PM me for details.
Worldwide shipping is available. PM me for a quote.
1 pair
NIB
- 1 pair 6.7” Extended-mid bass woofers
- Frequency response 55 Hz - 4000 Hz (door mounted)
- Power handling: 150W RMS
- Impedance: 4 ohms
- Sensitivity: 88.1dB
- Mounting depth: 2.94”
- Cutout diameter: 5.87”
- Cast frame: OD 6.7”
- Cone: Mixed Kevlar/Fiberglass
- Magnet weight 30 Oz
- Cone surround: Butyl rubber
- Fs: 52Hz
