CD player won’t play
What model is your CD player?
I‘m not sure! I looked over the face of the unit for a model number but there is none. The unit is a factory supplied McIntosh unit by Subaru for the VDC Outback from that year. Radio appears to work fine. When I try to play a CD, I get the er - 06 message.
I looked on a few Subaru forums and found some threads with the same/similar issue. Pretty much it's your deck not reading the CD due to dirt, dust, or the laser is failing. It's recommended to clean the CD or run a laser cleaning disc through your deck (like the old CD/DVD cleaner ones with the small brushes on them). Hope this helps!
Is there a BT, USB or other AUX option? May be time to convert your CDs to a solid sate option and use it until you replace the init altogether.
199
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
AGAIN sonic does the same install stuff for free as well! Get a head unit with 4v preouts and 6 rca preouts as well they will be setup as front...
19
Nebraska
firey_kimchi
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
