Case Fan Relay Help
87-fused 12v ......86-12v turn on in....30 12v output........85 ground.
So 87 and 85 are 12v constant and ground (easy) The 86 is the remote wire input from the HU and the 30 is the power pin for anything I wanna run? That's where I splice my amp remotes as well as the fans right? I just pick up a socket for the relay and connect to the precut wires?
So 87 and 85 are 12v constant and ground (easy) The 86 is the remote wire input and the 30 is the power pin for anything I wanna run? That's where I splice my amp remotes as well as the fans right? I just pick up a socket and connect to the precut wires?
yes sir.
---------- Post added at 10:30 PM ---------- Previous post was at 10:30 PM ----------
87a will not be used in this situation.
---------- Post added at 10:31 PM ---------- Previous post was at 10:30 PM ----------
i would just solder straight to the pins, and heat shrink, instead of wasting money on a socket.
i'll try to take a pic of mine on where to wire the power and ground from the fan and the power and ground from the relay and remote to relay. its actually pretty easy if i can do it, i am sure u can, but i will take a pic of what i have if it helps u
coolername
coolername
Bellingham, WA
bradl79
vegang
vegang
