Carputer Update Part Duex
nicely done, i should do that i got a a few computers laying around :p
the only thing i am worried about is what happens if theres a power flux of some sort?? do you run like a low end battery backup or something??
Because thats what i was thinking of doing but i just dont know were id put it right now...
:p you can alos set it so when you turn your car off with a battery backup it automatically goes into hibernate and you dont have to touch a thing ^.^
I believe the ATX power supply spec sends a Sleep if you just press the button once; Could work that out with a relay from the ignition/remote lead. =)
lol :p yar me newb...
Anyways... Intel=deh suxors //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif wouldnt recomend it for a carputer with not to much ventilation not enough cooling on those LGA chips and the 478's :p
So, How does the audio sound i wounder with this.. :p any issues with that ect...
Socket 478? The core duo is in macs, and you can bet they're hardwired and runnin' chill.
I wouldn't recommend an hot overclock on a p4 in your carputer, but [^almost] anything running at or below spec should be fine. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
cpu throttle = pwn.
Remember that the carputers aren't running whole instances of Windows, etc. Just a tiny trimmed up OS. I'd run it on a ramdisk, too.
n00bx //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I give you +rep for bustin my balls
Im seriously contemplating doing this...are there any programs that allow you to run active crossovers?
I'm running an active crossover with my carputer and digital sound. I have the Alpine PXA-H701 with the Alpine RUX-C701 controller. It has an active crossover, graphical and paramteric eq's, time delay, accepts both optical and rca inputs, and has 4 sets of 4V rca preouts to run to your amps.
I'm running a digital coax cable from my motherboard to a coax to optical converter to an optical audio cable to my alpine. From there, I run two sets of actively filtered RCA's to my 300/4 and one set to my sub amp. It's a crystal clear, noise free set-up.
nicely done, i should do that i got a a few computers laying around :pthe only thing i am worried about is what happens if theres a power flux of some sort?? do you run like a low end battery backup or something??
I'm running a regulator that is designed specifically for powering a computer in an automotive environment. It takes varying input (to survive engine cranks and varying voltages) and give a clean regulated 12V to my carputer at all times. It has a built in start up/shut down control that turns on when i turn my key and turns off when i put my key in the off position.
This works almost like an amp with a regulated power supply (gives u constant voltage no matter what and has a switched remote wire). When i turn my key to the off position, the computer thinks that the power button was pressed and it goes into hibernate. When I go to start it after that, it comes back in less than 10 seconds.
Randy Savage
Randy Savage
New York
3onDubs
