Capasiters?
thanks for your help. I will pass on the capasiter. as for the tweeters. is it fine to put them inline with the speakers. I just could not figure out how the amp would seperate the two. does the pass. crossover help here? again thanks.
I have replaced the batt with a cold start 600, and I have had to replace the alt. for the last 2 years. I ran a test on the charging system and found that when I pulled all the fuses and checked each circuit as i re installed the fuses that when I installed the fuse to the batt. and then put the stereo (batt.) wire in I got a short. I re checked my wires and they all seem good. I have added a electric fan but again thats not a lot. it just seems when I unhook the stereo alls seems good, good charging, lights bright etc. but once I kick in the stereo my alt. gauge starts to go eratic.
How exactly is this amp hooked up?
I have a main wire runnig from the batt. to the amp it has a 20 amp fuse in line. there is a wire running from the stereo to the amp and I have a ground wire to the car chassis within a couple feet of the amp wire gauges are what I was quoted from the instuctions from the amp.
john-1956
john-1956
Anderson, Indiana
john-1956
