Capacitor voltage not stable,why?///initially charge to about 8.5 volts?
fire919
ok so i bout this capacitor Tsunami PP1002TM-CAP (pp1002tmcap) 2 - 2.9 Farad Capacitors Car Amplifier Installation & Accessories Car Audio/Video Installation & Accessories Car Audio, Video, & GPS Navigation - Sonic Electronix and i charge it with a resistor before usage....the voltage went to around 8.5 volts. i remove resistor and connected power directly...(everything was connected correctly grounded etc) the voltage when car is on without music playing (ACC) reads about 14-14.2 volts and when i play my music it drops to as low as 10 volts then goes back up to maybe 12 volts, then 11 volts, then 13 volts continuously....i know that when i am playing my music there is a possibility that voltage drops from 14 volts if only a little on capacitor readout. But TRUST ME there has to be somthing wrong bcuz there is no way the amp/subs that i have a able to do this. I have a SPL 620 watt amp http://www.sonicelectronix.com/item_7728_SPL+DK2-620.html .
....please dont worry about hardware (amp etc) i knw it **** and alla dat....i jus wanna knw y is this happening if anyone knows or has an idea
Go to autozone or something and get your battery and alt tested. Something is wrong and needs to be fixed. Cap=junk/waste of money. Go sell it so someone else who thinks they work too. From this point on...you no longer believe in caps.
fire919
fire919
the bronx,NY
daboyfrumdabx
