Capacitor Question
First things first, install your existing setup. If you have 200wrms subs and 75wrms to them, try it. Play with knobs and button, what direction your subs are pointing, where the subs are, etc. If you can't get it to sound good, look into something better. And stick around here, because some people here know their stuff, and you can learn.
Oh god would the boys at circuit city have a heyday with you.
I told you in a previous thread that that amp is too small.
http://www.caraudio.com/vb/showthread.php?t=109088
I will tell you again-
That amp is too ******** small to power your subs.
You need a 500watt RMS amp that is stable at a 2ohm mono load.
Kenwood KDC-8152, costs 150 bucks and will work perfectly for your needs.
http://www.salectronics.com/detail.asp?product_id=KAC8152D
When you look at its ratings and you see the 1100watts, that means nothing it must say RMS power to mean anything, if you look you will find 550 watts RMS into a 2ohm load.
Use the Pyamid amp you bought to power a couple 6x9's or somthing like that.
GReddyBooSTer
GReddyBooSTer
FL
stones
