Capacitance difference?
qtipextra
The Original
Im building this, but I dont have the capcitors. The schematic says the capacitors should be 35v, 100uF. I have 35v 1000uF capacitors. My question is, if you have something that will store more then neccisary, or that is more the it specifies, is that a bad thing? Could I use the capacitors with 10X as much capacitance? Or should I just order 100uF ones?
I imagine your using this for pro audio.. if you are, you really need to follow the schematic. Especially for a phantom powered device.
Shit, I was afraid someone would say that.
What would it effect if I did use the 1000uF instead?
The voltage output by the device will either go up or down.. I need to re-look that diagram to tell you for sure.
Either way thoug.. that's something you don't want it to do.
qtipextra
The Original
qtipextra
Idaho Falls, Idaho
murphy54
Mike Mccabe
