The car is a 1997 Infinity Q45. I took out the malfunctioning Bose double din to install a double navi unit. The radio is good because I hooked it up straight to the battery and it came on. I checked the radio fuse on the radio and the car's fuse box and they are good. I used a multimeter at the plug and the red and yellow wires read nothing. The only thing that is working is the power antenna. When I unplug the wire harness from the back of the radio the antenna retracts. Maybe it has something to do with the factory amp? I'm not getting any power from the ACC or Battery. I'm thinking about running it another way. I'd have to run a wire from the fuse box for the ACC and straight from the battery for the yellow wire. I wish there was an easier way, but I've test lighted everything all day and can't figure it out. It might be a fuse or relay under the hood? There is one lose plug that was in the Bose that is not being used, but the wire harness only has 2 plugs. I'm sure this has nothing to do with it. Does anyone know what the problem is?
