Can U Help Answer My Questions?
  • 3
Y2mkk2
I just perchased 2 Alpine 12'' type-r's in a ported box for my Jaguar X-type. i also bought a Kenwood excelon 1000 watt amp. i was wondering if i should go with another amp, or if that one was good. I was thinking of upgrading to a Diamond 600 amp, but im not sure, and another question why in cars are the subs always pointed towards the back.
Keep in mind i got all this for $500 all new, and installed.
My subs are Dual 4ohms so are they wired at 4 ohms or another ohn
Thanks for any replies I really apresiate it.
If the kenwood is 1000 rms it will be fine, i think kenwood amps are sometimes overrated, so you should be ok. If you want to spend the money the diamond would probably be fine, but i don't really see the point.
-Jason
I have to agree about kenwood being overrated. They're not a bad amp. If your not looking to try winning Ultra Pro sound quality, it will work fine.
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
321
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
299
11
541
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
6
349
Y2mkk2
Y2mkk2
Tarpon Springs, Fl
Diplexers
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
