Can someone please tell me whats going on with my amp
it was set to measure 12v on the dmm. did i do it wrong?
Somehow, yes. Set it to measure DC voltage then measure the voltage on your battery, I'm only telling you to do this part so you can verify you have it on the correct setting, you should get the same results as before. Then without changing anything, go to the amplifier and with power and ground cables still connected to it, put the DMM leads on the amp terminals to measure the voltage there. Make sure your getting the DMM probes onto metal, just use your head when it comes to reading the meter. It SHOULD read the same as the battery does (both with the car on and off). If it's reading a crazy high number like 79 then make sure it doesn't say "mV" somewhere on there because that means millivolts. Post back with results.
and the amp is at 2.37v now
This doesn't make any sense, I told you to disconnect the amplifier so it shouldn't be reading anything...because it's not connected
How are you only getting 2 volts? You're sure it's not 12.37? I told you to use your head when measuring the voltage, if you didn't already deduce, 2 volts is way way too low.
My only suggestion at this point is to get the amplifier to someone who knows what they're doing. Not trying to be a dick but we're getting nowhere fast. Your answers are vague and it's difficult to help someone diagnose problems when they don't have a lot of experience with electronics.
what? i did what you asked me to do and im telling you what the meter said im not blind it said 2.37 volts i know its low which is why i want to figure out the problem
but we always start with a DMM and measure voltage.
next, we use that same DMM to measure VAC out of the amp speaker terminals to look for a signal.
then we use that same DMM to measure resistance (ohms) of the speaker wire (disconnected from amp) to verify sub wiring.
First, completely agree with the above ^
The problem now seems to be that it looks like the amp may already be damaged and therefore, a DMM measurement at this point would be futile, no?
Nothing in this thread has confirmed that so I wouldn't jump to that conclusion. If he still had that amplifier connected to the vehicle's electrical system and it was reading 2 volts on the terminals then I think he would be seeing some fireworks. You can't just drag the entire system voltage down to 2V and not damage things, which is why I still think that 2V reading is nonsense. Was that a reading you took from the amp while it was disconnected? (perhaps just some leftover charge from the internal caps?)
OK, that is what I figured...I was trying to understand how the hell he could be getting a good voltage reading at the battery and then if you trace the power wire down to the amp's positive terminal, you get 2V. Seems odd to me as well.
OP, do you perhaps have a spare amplifier that you know works that you could swap out?
Can you please explain the circumstances surounding that 2V reading? Amplifier connected/disconnect, car running/off?
I had two of the Xtreme 12's and they were dual 4ohm. They read at like 3.5ohm per voice coil which is common.
Still not convinced? https://gpcaraudio.com/15-dual-high-output-glue-it-screw-it-sub-enclosure/ You can order the box glue and screw kit with...
15
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
4K
suteman
suteman
Pway, NJ
ngabria1
    May 18, 2024
    May 16, 2024
