Can someone clear this up for me? 2nd Battery question!!
  • 6
The main thing is that the resting voltage of both is relatively close. The stronger battery will try to charge the weaker one when your vehicle is off.
this is true but you must also use the same type of battery ie .. agm ,wet cell
i had mine mixed time and time again, and never had a problem with mixed batts. i mean now i dont because i dont have a battery under the hood at all. i have my truck ran off the rear batt bank until i get a good battery to go under the hood because my other one took a sh1t.
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
Still not convinced? https://gpcaraudio.com/15-dual-high-output-glue-it-screw-it-sub-enclosure/ You can order the box glue and screw kit with...
15
4K
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
4K
03Bonneville
03Bonneville
Lincoln, NE
mylows10
