Can RF Punch HX2 handle a KX1200.1
OldManTod
Grilling is my Passion!!
I have a few pennies to spend and see some folx unloading kx1200.1's. I already have one and am thinking about another for the 12's...
I have two RF Punch HX2's in a slot ported box (~2.0 cubic feet) and I am wondering if I am better off to grab another kx1200.1 to drive one HX2 (12") and grab another 1200.1 to run the second..
Or should I keep them wired the way they are (I believe they are wired down to 1 ohm, the posts on the subs are wired together and then the wires on the box are wired together to the amp...
Just trying to kick it up a notch..
T
isnt the max rms on the hx2 about 500 each ?
I highly doubt if one hx2 can handle the 1400 watts that kx is putting out . to me it seems a little steep for even two . maybe im wrong ?
My buddys zr360 was wanging the hell out of his hx2, I'd say hook a kx1200 up to the both of them and it will be crazy loud(if your subs are dual 4. By a 2 cube box, you mean 2 cubes per sub, right?
if they are both DVC 4's, it would only give a 2 ohm load on the KX12001 so maybe 800 watts to each...i say keep one. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Please tell me your box is 2ft^3 each:)
And the old Hx2's can take more than there share of power but in your situation I would stick with the 1200.1
That is a perfect amount of power for them. You will probably not notice a gain if you were to put one on each sub.
I'd buy the amp anyways if it's a good deal.You can always use it later if you get different subs etc //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
OldManTod
OldManTod
Cle-burbs, OH
blackgeltabs
