can anyone???
loudazz09
loudazz09
can anyone believe this stuff ... 180.2 DBS WITH 2 OF THESE HELL SCOTT OWENS SHOULD HAVE DONE THAT
Showing 1 review for Pioneer Premier TS-W8102SPL
January 12, 2009 Pioneer 3000W rms
Overall
Durability
Value
Features
Design
Usability
Review written by Drew from Johannesburg, South Africa
I got 2 hooked up to my 1990 Toyota TWINCAM powered by a KICKER warhorse and the bass is just INSANE!!!!!!!!!!! On spl testing it pushed 180.2 DB's I would recommend this sub to anyone who wants to blow their eardrums!!
Pioneer Premier TS-W8102SPL8000W Max, 15" Dual 2 ohms SPL Champion Edition Competition Subwoofer Add to Wish List E-mail a friend Print this page
Customer Rating
(1 Review) View Larger Images
$1,699.99 List Price
-$1,010.00 Instant Savings
$689.99
Protect Your Investment with an Extended Warranty
Choose From Extended Service Plans As Low As $77.993-year Extended Service Plan by SquareTrade - $77.994-year Extended Service Plan by SquareTrade - $90.99
Availability: In Stock - Ships the same or next business day
USA Shipping Estimator
+ Outside the U.S.?
DescriptionFeatures & SpecsReviews
15" Premier Series Subwoofer
Power Handling:
Peak: 8000 watts
RMS: 3000 watts
Interlaced Carbon Fiber Reinforced IMPP Cone: The cone of the TS-W8102SPL features a patent-pending design that combines long carbon fibers into a proprietary blend. The strong, lightweight characteristics of carbon fiber render a robust IMPP cone capable of withstanding the enormous pressure levels the speaker is capable of generating.
Aramid Fiber Reinforced Rubber Radial Surround: When a subwoofer is working overtime, the cone exhibits dramatic movement that must be controlled appropriately without compromising the actual sound quality. The same material used in bullet-proof vests, Aramid Fiber is woven into the rubber surround producing a superior material that eliminates puckering and improves highpower performance.The overhung design allows for a 22% larger cone surface which translates to even more sound pressure.
Ultra-Strong Dust Cap With Foamed Acrylic Polymer
Aero-Dynamic Magnetic Gap (ADMG): As a speaker operates, the movement generated between the top and back plates is subject to resistance, both mechanical and air pressure. To reduce this resistance, strategic channels are precisely machined into the top and back plates. This effectively reduced physical resistance by more than 10% and thus reduced power waste making the speaker even stronger.
Cast Aluminum Basket
Projected Pole Yoke with Vented Pole
Precision Dual Damper
1.2" Thick top plate
Overhung Surround Design
Titanium Voice Coil Former (Bobbin)
Dual 2 ohms 3", High Inductance, 6-Layer Ceramic-Coated Voice Coil Wire
320oz. (20 lbs.) Ferrite triple stacked magnet
Frequency response: 15-1500 Hz
Sensitivity: 91 dB
No warranty
Subwoofer Specifications
Subwoofer Size 15"
Voice Coil(s) Dual (2 voice coils)
Impedance (per voice coil) 2 ohms
Peak Power Handling 8000 watts
RMS Power Handling 3000 watts
Woofer Surround Rubber
Woofer Composition Interlaced Carbon Fiber Reinforced IMPP
Sealed Box Volume 2.50 cubic feet
Ported Box Volume 3.25 cubic feet
Sensitivity 91 dB
Frequency Response 15 - 1500 Hz
Xmax (millimeters) 15.4 mm
Top Mount Depth N/A
Cutout Diameter N/A
Warranty No warranty
Warranty and Return Policy
Standard Warranty for Subwoofers
Review Summary
1 person rated the Pioneer Premier TS-W8102SPL and gave it a rating of 5 out of 5
Have you used this product? Click here to review it!
Overall
Durability
Value
Features
Design
Usability
I got 2 hooked up to my 1990 Toyota TWINCAM powered by a KICKER warhorse and the bass is just INSANE!!!!!!!!!!! On spl testing it pushed 180.2 DB's! I would recommend this sub to anyone who wants to blow their eardrums!!
loudazz09
loudazz09
loudazz09
always bump'n , nc
WhiteIce
