i dont exactly understand how just pitching 1 blade would create roll (im assuming you mean to some something like a barrel roll? bare with me i really have no idea what im talking about) because its not like a air craft wing that stays in the same location. helicopters blades spin a circle so i would think that force is going to go from 1 side to another to another and not do much of anything no?lift is created when the pitch of the blades is changed so that the leading edge is above the trailing edge. the amount of lift varies upon the pitch applied. when a helo is just sitting on the ground, the blades are flat, therefore keeping it on the ground. i know on a blackhawk helo, each blade is independently controlled with it's own pitch control. one blade could have more pitch than the others, creating roll. for a helo to fly inverted it would take a skilled pilot to roll it 180*, then stop it from going all the way over. the physics exist for it to work, but it depends on the aircrafts capabilities. i was a helo mechanic a couple years ago
ok, when the blades are spinning, this creates a "disc of lift". when one of the 4 blades has more pitch, it makes that side have more/less lift, causing the "disc" to rise/dip to compensatei dont exactly understand how just pitching 1 blade would create roll (im assuming you mean to some something like a barrel roll? bare with me i really have no idea what im talking about) because its not like a air craft wing that stays in the same location. helicopters blades spin a circle so i would think that force is going to go from 1 side to another to another and not do much of anything no?
thats what im not understanding though. since its spinning all the way around really quickly, i would assume it would make the helicopter just wobble front to back side to side really quickly since that force is being applied to all the sides as it spins around. like before it can push enough force to get the helicopter to flip that blade is already on the other side creating the same force in the opposite direction.ok, when the blades are spinning, this creates a "disc of lift". when one of the 4 blades has more pitch, it makes that side have more/less lift, causing the "disc" to rise/dip to compensate
well that answers everything LOLok, when the blades are spinning, this creates a "disc of lift". when one of the 4 blades has more pitch, it makes that side have more/less lift, causing the "disc" to rise/dip to compensate
and when i say one blade, i dont mean it stays on the one blade. it's at a certain point in the rotation that only 1 blade gets the different pitch. say you want to roll right. you would want the right side of the disc to create less lift than the left. so you would increase the pitch on the left side.
Repost from the first page newb //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
hahaha holy shit...when the firework things shot out i though it blew up....
