2002XLT
Thats right bishes...
i believe there is one copter, the comanche that can. not sure if thats the exact one, but im pretty sure it is.
i'm sure the motor switched direction of the turn when he flipped it pretty quickly. kinda like a car, switching from drive to reverse. being it a toy and having super light weight blades i'm sure that little motor can handle the switch over.wow, that is exactly what i did not expect to see. how the hell?
i would think flipping the helicopter over would make it fly faster towards the ground. wtf
i think i found it. seems like this guy knows more about those toy helicopters than i do lol. pretty much what you said, but switch the blades, and not the motor.i'm sure the motor switched direction of the turn when he flipped it pretty quickly. kinda like a car, switching from drive to reverse. being it a toy and having super light weight blades i'm sure that little motor can handle the switch over.but an actual helicopter takes a min for it to even gain enough speed for lift off. if a helicopter tried to reverse it's blades in mid air they'd probrably just fall to the ground not being able to get the proper velocity required.
does that make sense?
so, the pitch of the blade is adjustable from the remote control i would assume. but then again, why would they even have that lolYou just change the pitch of the blades from positive to negative.
when you have positive pitch and the heli is upright it pushes wind towards earth.
when you have negative pitch and the heli is upright it pushes the wind towards space.
So when the heli is upside down with negative pitch you are pushing the wind to the ground lifting the heli up.
OMG i would literally cry if i were in a helicopter doing that... i cant even imagine how scary that must be...
i would assume these people dont value thier lives very much. or are addicted to adrenaline. or maybe crazy. or maybe a combo of all three.OMG i would literally cry if i were in a helicopter doing that... i cant even imagine how scary that must be...
Sorry, but that's retarded. There is no way a cheap toy helicopter is going to be equipped with a motor that can switch direction that quickly. And it wouldn't work that way anyhow. The reason it can fly upside down is because the "cockpit" only weighs a couple pounds. The blades are angled slightly, but when you flip the heli 180 degrees, it's the same angle. A real helicopter couldn't sustain flight because too much weight would be above the point where lift is generated. But for a two-pound piece of plastic, that's really not a problem.i think i found it. seems like this guy knows more about those toy helicopters than i do lol. pretty much what you said, but switch the blades, and not the motor.
