can a DD 3500 12" take 2000 wrms daily?
you can get them in dual 1...I'm running one at 3000 daily with no issues....//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
somehow i just knew you'd be the first to answer......//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
do you think 2 12"s in a 6^3@35htz box on 2 IA 20.1's would be a good setup. If not what box size/tuning would you recommend. Keep in mind this a daily street beater playing nothing but music
i wouldnt put 2k daily 1500 would be ok. I did mine 1k all day and they wanted more but 2k i wouldnt do it for daily. I believe they make them in whatever impedeance you want them to.
I would be wary about strapping a pair of IA 20.1s @ 1 ohm to a pair of 3500s because that is a lot of power. But Louisiana_CRX says it's okay. You be the judge. I say be very careful - gain the amps down to a safer amount of power.
not strapping...running each one individually...same result in the end i guess....besides in reality they most likely won't see 2000 watts. I run Alpine decks and i never go past 25 and i set the gains pretty conservatively
Then you should be fine.
I run a pair of 3515E's on 2 20.1's strapped at 1.5ohm dialy.
They take it like a champ. (Oh...and burp at .375 strapped)
Try 5cuft w/ that much power though.
Keep the signal clean and you are golden.
I run a pair of 3515E's on 2 20.1's strapped at 1.5ohm dialy.They take it like a champ. (Oh...and burp at .375 strapped)
awesome....exact what i was looking for, Thanx
bonesninja
bonesninja
Lima, Ohio
bonesninja
