Can a 15 L7 handle the power?
^^^ got me a box already //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif but theres a problem, one is blown so i took it out and i know have a pointless box for 2 15"s, is there anyway i can cover up the hole to close off the box a bit (its ported) ...i tried place'n a piece of MDF over it, and it rattled like crazy....anything else?....its just temporary untill i get my new 15"
how big is the box? is it apre fab box? your gonna need at least 4.5 cubes net for the 15 to take that amount of power.
For a driver to handle power, you would put it in smaller box, not larger, as you are reccomending...
You can only wire that subwoofer to 2 ohms, so you won't get 2500w to it regardless. It will be fine at 2 ohms, in whatever box you have. I would not reccomend using the same box you had them box in, though; because that would be twice the required air space for a single L7. It will work, but won't be optimal.
A:) Gain has nothing to do with the power at peak.
B:) If you are tying t use teh same box and the driver shared the volume taking one out and capping the hole will really hurt your tuning which may cause you driver to fail.
Other then that you shouldn't have a problem runing that amp and one sub runing the coils in parallel.
I was hoping someone would notice that...
MA$E
CANT MOB LIKE ME
MA$E
San Jose, California, United States
Josh #44
