F fatboyracing 10+ year member CarAudio.com Veteran 2,755 1 Owensboro KY Nov 26, 2007 #1 could I wire each sub in series to make themm 8 ohms each then all 4 in paralel to get 1 ohm? Click to read more...
KidThump 10+ year member V.I.P 1,905 4 Georgia Nov 26, 2007 #3 No, 4 dual 4 ohm subs can be wire to 8 ohms, 2 ohms But, 4 dual 2 ohm subs can be wired to 1 ohms, 4 ohms
OP F fatboyracing 10+ year member CarAudio.com Veteran 2,755 1 Owensboro KY Nov 26, 2007 Thread Starter #4 Are you sure it make sense if they where wired each in series it would be like 4 8ohms series right
T tez4life Premium Member Premium Member 4,037 1 Mobile, Al Nov 27, 2007 #5 Wont work, you wire each in series that becomes (4) 8 ohm loads. All those in parallel (4) 8ohm speakers will give you a 2 ohm load. Only way to get 1ohm with (4) speakers is with (4) 4ohm subs or (4) Dual 2 ohm subs wired in series first than parallel
