calculating cone area
Only part of the surround is allowed to be used in calculating Sd. Even the part that gets used actually is a function of the movement of the cone and decreases as the cone moves further in and out.
Most respectable sub companies will list Sd. I don't know any companies that I would buy from that don't.
Yes, the formula is A = Pi * r * r
The obvious: It's the cone diameter (not the subwoofer diameter) that is used.
Example: Polk 8" MM2048
Mount Diameter: 7.0625in
Diameter of cone: 6.65in (radius = 3.325in)
3.14 * 3.325 * 3.325 = 34.71 sq-in
(specs: http://www.polkaudio.com/caraudio/specs/mm2084/ )
For the example above, I simply took the Sd and worked the formula backwards.
Got it now. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
????help? my sub is 1029.2 cm2 how much sq-in is that?
damn tc, damn audiopulse
budahbuddy803
budahbuddy803
Aiken, SC
jeremiah
