cadence txa 1000w help
come get some
hello folks maybe you all can help me. I have a cadence txa 1000w class d mono block amp. I have it pushing 2 blaupunkt (spelling) 10s that they "say" are 2000w each.. This amp has worked flawless for about a year-year and a half.. sounds great. I noticed a couple of weeks ago, that while u were listening to the stereo volume loud or low, car setting still or driving, that the amp would cut out at times and then come right back on. Like u was unhooking the speakers and it would go quiet or something. I check all my wiring from the battery back, (i have monster cable straight from the battery positive) to the power side of the amp, and a nice monster cable 3 foot ground going straight to the chassis of the car. Any way, i have a nice 10 guage power remote wire that is flawless going to just that, the power remote. Anyway with time it got to where it did it more and more and more. it started out only cutting out for like a second at a time, then gradually got to where it would cut out for minutes at a time. Now the past 2 weeks, it will not come on at all.. Tonight, i took and checked all my wiring once again, took my volt meter, check the hot, and ground wire, (12.3 volts car not running 13.7 car running voltage) and the power remote wires and still will not come on. i crossed from power remote to power directly still nothing. The power lights will not come on, not even to go into auto protection mode. Also i noticed that (after i busted the trunk light by accident) that the power green light is on just super super faint and real dim. Had i not busted the light i would have never noticed. Once again, all wiring is great, but the amp will not power completely up.. not even enough to make any sound from the subs. Tonight i took the amp apart (just the panels to see everything inside) and nothing is burnt, nothing smells burnt, nothing looks burnt, its absolutely clean as all get out inside the amp. ANY SUGGESTIONS BEFORE I LOSE MY FREAKING HEADDDDDDDD LOL.. (i blew the amp out with canned air before i put it back together and still nothing..
thanks in advance for all the help shall i recieve it
come get some
come get some
knoxville
come get some
