C&D Dynasty High Rate Max AGM Battery
USED
UPS12-210MR
Length 8.99
Width 5.47
Height 8.84
Terminals - C/FR Screw
Weight 40lbs
Manufacturer C&D
High Rate AGM Batteries in Excellent condition
all resting at 12.8-13.1V
Load testing indicates excellent capacity
High Rate UPS batteries like these are very well suited to car audio use do to their discharge characteristics.
These particular batteries are designed for extra long life and mounting at any angle.
210 watt 50Ah
10 year design life @ 25°C
Absorbent Glass Mat (AGM) technology for efficient gas recombination of up to 99% and freedom from electrolyte maintenance.
Patented UL Recognized Flamearresting vents in each cell for safety and long life.
Designed with the same recombination, thermal runaway prevention, gassing and flame retardant characteristics of the Bellcore 4228 compliant Dynasty Telecom products.
Flame retardant polypropylene case and cover compliant with UL 1778
Proprietary Fixed Orifice Plate Pasting technology applying active materials on both sides of the grid for consistent cell-to-cell performance, higher capacity and uniform grid protection.
Thermally welded case-to-cover bond to eliminate leakage.
Can be operated in any orientation. Upright, side or end mounting recommended.
Not restricted for air transport - Complies with IATA/ICAO Special Provisions A67.
Not restricted for surface transport - Classified as non-hazardous material as related to DOT-CFR Title 49 parts 171-189.
Not restricted for water transport - Classified as non-hazardous material per IMDG Amendment 27.
$75.00 Shipped Get'em while you can
INCLUDED
UPS Ground Shipping anywhere in the continental US
If you prefer another shipping partner let me know via PM and I can work with you.
I have partnered with @Boomsday For discounted shipping.
USED
UPS12-210MR
Length 8.99
Width 5.47
Height 8.84
Weight 40lbs
Manufacturer C&D
210 watt 50Ah
INCLUDED
