Bypass ignition cutoff in scorpion alarm?
NoPh33rRaCiNg
One of my friends just got a older lifted suburban, his alarm doesnt work anymore and he has to hotwire it to get it started. it has a really old scorpion alarm, never heard of it... but what basic wires would you usually have to play with to bypass that so he doesnt have to hotwire it all the time? what color should the wires be?
I doubt anyone will be able to tell you the alarm colors but if he is hot wiring it he knows the vehicle colors so start there.
Also why not take the alarm out if it doesnt work?
he wants to take it out so he can hopefully just connect the two back together that are making it so he cant start it normally. i dont know how wiring works with alarms just seeing if anyone has any ideas //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Depends on whether or not it's onboard or outboard starter kill. If it's onboard, then the starter wire will be cut, and you just connect it back together. A butt connector is sufficient. If it's outboard, just unplug the brain. It sounds as if it's onboard, though.
NoPh33rRaCiNg
NoPh33rRaCiNg
Kent, WA
Ferendon
