Bxi 2006D vs. Power Acoustic 3000db
bigt
Another comparison needed between these two, I have researched alot and they both seem like their good budget amps. What do you know about them that I dont?
BTW this is my 1st system so their may be things im not aware that is better on one than the other.
Specs-Hifonics Bxi 2006D $340
* Number of Channels 1 - Mono
* RMS Power (4 ohms) 650 watts x 1 chan.
* RMS Power (2 ohms) 1300 watts x 1 chan.
* RMS Power (1 ohm) 2000 watts x 1 chan.
* Bridged RMS Power Not Bridgeable
* Peak Power Output N/A
* Min. Impedance Unbridged 1 ohm
* Min. Impedance Bridged Not Bridgeable
* THD @ Rated RMS Power
* Speaker Level Inputs Yes
* Amp Preamp Outputs Yes - 1 Pair
* Built-in Crossover Yes - LP
* High-Pass Crossover N/A
* Low-Pass Crossover 35 - 250 Hz
* Subsonic Filter 15 - 50 Hz
* Signal-to-Noise Ratio >95 dB
* Channel Separation N/A
* Bass Boost 0 - 18 dB
* Bass/Gain Remote Yes
* Fan Cooled N/A
* Fuse Rating N/A
* Warranty 1-year SE
Planet Audio EDIT:power acoustik $300
CLASS D SERIES
* Hi Speed Digital Circuitry
* Fully Regulated PWM Power Supply
* Four Way Protection Circuit
* 1 Ohm Stable
* Bridging Synchronization
* Variable Low Pass 50Hz-150Hz
* Variable Subsonic Filter 15Hz-40hz
* Variable Subwoofer EQ @ 45Hz
* Phase Switch 0-180
* Remote Dash Mount Low Level Gain Control With Cable
* Frequency Response: 15Hz to 150hz
* S/N Ratio: 100 db
* THD: 0.5%
* System Distress Indicator
* Inputs Sensativity: 200mv-8v
* Dual Mono Speaker Output Connectors
* Gold Plated Heavy Duty Power & Speaker Terminals
A3000DB
4ohm 1100 watts
2ohm 1800
rms (pretty sure @1ohm)2300
max 3000
Ive seen PA amd owned 2 hifonics amps, you can't strap hifonics go with pa so if you want to upgrade you can just buy another and strap them. Also seem to hold resale value a little better than hifonics.
i would get the power acoustik,they wont do rated power, but it will probably do atleast 3/4 of the rating..if not slightly more. i would buy another power acoustik anyday
Finally some posts!!! ok well the PA takes 4 awg doesnt that seem small compared to the hifonics which is runnin 2, Im plannin on runnin 0awg throughout my car and how am I suppose to get that big 0 awg in the 4 hole? sorry first system but I could use some help.
I ran 8 BXI2006D's in my Blazer for most of this past year. I ran the amps at .5 and beat the crap out of them. They never got hot or shut off or went into protect. They took Kicker 0Ga. without any trimming. Did a 157.8 at SBN at 37hz.
I have sold the PA amps but had more returns for repair than with the HF.
NeillBarber
I honestly believe in Hifonics. I can vouche for NeillBarber on this one. Ive ran my BX1000D..its one of the old models at 1 ohm for over 2 years now and its still going strong and has NEVER went into protect mode from overheating...ever. In fact running full tilt it doesnt even get warm at 1 ohm. I believe Hifonics rates their amps correctly but I think they flurb on their ohm ratings...more like rounds them off. I have no doubt in my mind that Hifonics amps can put out rated power with ohm ratings slightly below what theyre rated for.
bigt
bigt
USA
80_Cutlass_mn
