Buying amp 300RMSx2
Those subs are SVC 4ohm so you could use the 1200D with these subs. Just run the VCs parallel to give the amp a final 2ohm load. This amp will put out a little more than what these subs are rated for so be easy on the gain knob.
Output Power 14.4V @ 1% THD 510X1 @ 4 ohm
Wouldn't that give me 255 each if I wire them in order?
no, these subs are single vc right? each sub only has one + and one -. if you wire the + from sub one to the + to sub 2 the from sub 2 to the + of the amp and then do the same for the - you will end up with a 2ohm load on the amp
Two I believe... You mean the things that you can put crimps on? Also, even if they didn't, could I not just use the same post for in and out?
post a picture of the back sides of your subs.
We'll tell you what to do.
Also, I have a sundown sae1200d for sale, pm me if interested
And sundown > AQ
ArcFault
ArcFault
Canada
t1990le
