Buick Grand National Owners
there is no such thing as a Grand National T-type...........................
it's either a Grand National or a T-Type
Umm there are t-type grand nationals I should know I have one. It's an 84 witht he 87 motor swap with some work done to it last time it was at the the track ran a flat 11 with massaged stock utrbo.//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
I'm thinking of switching to a front mount IC does that make much of a difference? I guess then you can do away with the front fan and go to an electric fan with less drag on the motor
Do you mean take off the motor driven fan for the intercoooler? the fan up front is electric:confused: As far as front mount intercooler goes I personally don't like the looks of them on the grand nationals you can get upgraded intercoolers that go in the stock location that do alot better of a job that's what I'm going to do.
front mounts can make a huge difference in HP but are a biotch to plumb in.....i would go with a mies stretched stock location IC much easier to install , but you wont get the same performance gains as a front mount
although a front mount IC looks means as hell sittin behind a 87 GN grille:up2somet:
if you want to upgrade your cooling system try a 3rd gen camaro radiator and 98-02 intrepid dual electric fan setup......youll drop @ 15-20 deg in water temp
I may look into that...Mine has the 87 motor swap...and grill //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif So this is something I'll really consider....I haven't had the chance to work on it much latly....I'm trying to figure out the replacement door top and trunk rubber....hopefully I'll have that swapped soon...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Louisiana_CRX
dem shoes......
Louisiana_CRX
Piney Hills of Louisiana
Louisiana_CRX
