Budget Friendly Northstar SMSAGM80 NOW AVAILABLE
more pics
Going for a 370 from singer or mechman
Whats up man, with that alternator and depending on how underrated the ampere 5k's are, I'd do 2 to 3 Northstar SMSAGM400
A local was running an ampere 7.5k on 2 Northstar SMSAGM400 with a 300 amp alt and would typically hold just under to over 13 volts non stop demoing on music.
All that's means was his ampere 7.5k wasn't even pulling 300a of current.
here's the specs on the smsagm80 if you're like me and too lazy to open up an external webpage ('mericuhh)
40AH
1500 amp SS Current
820 pulse amps
400 cca
Will last 900+ cycles in extreme recharge and discharge conditions.
LOAD TEST RESULTS
Youtube video link below
Northstar SMSAGM80
Specs, 40 AH
3.8" x 9" x 10"
35 lbs
Only loading it down to 11 volts was the target, because when you throw an alternator into the scenario while a car is running/ at charging voltage and amperage you'll be in the mid to high 12s ballpark typically. Will vary based off of the size of the alternator, but regardless, this battery is a beast.
3) 15 second load tests back to back. in about a 1 minute span of time.
1st pull, 11.00 volts holding a 450 amps
2nd pull, 10.95 volts holding just over 450 amps
3rd pull 10.84 volts holding right at 500 amps.
not bad for a budget battery.
This battery is the EXACT same build design and technology as the Northstar SMSAGM400, only it is 1/4 the size, and under $200. We worked very hard with Northstar to make this happen and the results are outstanding! Enjoy the video.
GPcarAudio.com
Pro Seller
Supporting Vendor
GPcarAudio.com
Missouri
GPcarAudio.com
