Budget Friendly Northstar SMSAGM80 NOW AVAILABLE
GPcarAudio.com
Pro Seller
Supporting Vendor
Finally and Now in stock, the new Northstar SMSAGM80
We work very closely with Northstar battery and stressed the importance of having a budget friendly option for the 1,000 to 2,000 watt setups at the beginning of January and its finally finished! This battery conains the EXACT same technology as the Northstar SMSAGM400.
Picked them up fresh out of the factory today, all the preorders are shipping out today and new orders that come in today will ship tomorrow.
GP CAR AUDIO Ground & Power Ground Pounder
Small and compact, fits beside an enclosure easily
Dimensions 4"x8"x9"
40AH
How many you think it will take to support a pair of crescendo bc3500s?
Your going to want to go with 1 to 2 Northstar smsagm400 or 2 to 3 Northstar AGM31 on that much power and depending on your alternator size. These are designed to run 1 to 2k setups. When you start going into needing mutiples there are more cost effective options on the larger batteries.
What do you suggest for running 5k that's budget friendly?
Nsb makes great batteries I will be running 10 nsb60ft's with dual 270a alts powering 2 taramps 8ks. I'd rather run a bunch of small batteries due to lower esr for faster charge and discharge rates. I also got a killer deal so price was not a concern.
I have a singer 250a alt big 3 in 2/0 welding wire an dual runs of power & ground in 2/0 welding wire
GPcarAudio.com
Pro Seller
Supporting Vendor
GPcarAudio.com
Missouri
GPcarAudio.com
