Brutus BXI 1606D?
I don't know the size of the screw but you should be able to get one at your local hardware store. I usually go to my local Cenex (gas station) or maybe your local stereo shop has some extra screws from broken amps that will work.
Peace, Lee
you shall be able to get it at a local hardware store, it will be a set screw and they are cheap. if i remeber correctly it should be the same size as the ones for the speaker wire. take one of those out and try it in the remote wire hole, and if it works just take the speaker wire screw to the hardware store and tell them that you need another. should work out just fine. shouldnt be much more the 20-30 cents
97srad750
97srad750
Lexington, SC
Kold_Killa
