brother, please help me choose cable
I'm trying to change my standard subwoofer cable and confuse which cable to use.I'm using 10' treo subs, please suggest me good cable with a usd 50 budget.
Thanks a lot
Welcome to the forum my brother. 12 awg stranded 2 conductor wire (speaker wire) is not that expensive. Unless your dumping tons of power to your subs, or are running wires extremely long. $50 will buy you a rather large roll, which will be way more than enough. Take some string and lay it out like you want your wire to run. Then measure the string and see how much wire you will need for one run then multiply by number of subs. Then add a 4 or 5 feet to allow for error. It's always better to have to much than not enough. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
in my book cables are cables..... I.e a Rockford Fosgate (overpriced) system wiring kit compared to a (cheap) scoche wiring kit will make absolutly 100% NO difference.... not telling ya to get cable that will break apart or is so thin that if u look at it wrong it breaks but u dont need to be to picky... if it conducts electricity it will work....//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
How about the cable that connect the head unit to an amplifier is it any different ? any suggestion for the brand ?
Thanks a lot pal.
rcas are the only thing that i would even think about spending any real money on.... i have monster... other then that keep it cheap (within reason) cuz no matter how fancy the wire it all conducts about the same...
hopes2hopes
hopes2hopes
ca
Ctminime
Mike Mccabe
