Broken Zed Levi???
So apparently that light is an indicator for when the high voltage rails are turning on, or something to that effect. Which is cool, nothing wrong with that, actually a nice feature. But what is wrong is the fact that the amp kinda resets, or output at least flickers, when those rails switch off.
Of course, I don't fully understand how all that works, so this might not be accurate.
So apparently that light is an indicator for when the high voltage rails are turning on....
Yes, it is showing you when it bumps up to the high tier rail voltage. All his amps have this, he had designed into the board to simplify his own testing. It's not supposed to be anything the user should worry about.
Sound shouldn't be effected, because likely the circuit that switches rails reacts to demands in a very small fraction of a second.
Anyway, I know Stephen is out of the country this week but I'm sure he'll help you out.
gckless
gckless
San Antonio
gckless
