- Thread Starter
- #16
I am grateful to get the chance to make these mistakes on a > $100 speaker ^_^Speaker wire will fail rather quickly. As I said, small wires and flexing are a bad mix. Only hope you don't run enough power to set the cone on fire when the wires break and burn the insulation at the joint where it meets the cone. Burnt plastic on that terminal should be cosmetic only.
Now you're also pretty hosed from putting a tire patch on the cone with epoxy. you will NEVER get to that coil lead ever again if your repair fails. This is where CA glue is superior since some acetone will take it right off if you need to perform surgery in future.
thank you for the input
also, in what regard will the speaker wire fail? will the solder break?
