Broke off RCA's in amp.. HELP!
Ronisonce
Well I accidentally broke the RCA's off in my sundown audio saz-1000. Got 1 of the pieces out, other is lodged in the input on the amp. Stupid me goes and unscrews the input, I break the wire inside the amp. So now I need to run new RCA's and I have to figure out where to get a new input to install in my amp. I can NOT figure a way to get the little piece of RCA out of the input. Any suggestions are welcome, aside from the "you're an idiot" because trust me, I know.View attachment 26537302View attachment 26537303View attachment 26537304
just use a small tube like what people use to syphin gas just make sure you put cloth or something so when your ****** on it so it doesnt lodge down your throat lol and just resolder the green wire like how the other input is, be careful tho my saz 1500 rca wire was very britle and i ended up just adding to the wire with thicker cable, it also made it alot easier to solder because i had more room too work with. hope this helps.
Tried the syphoning technique, was a no go.. I decided to drill it...I used a small enough drill bit so I just got some of the insides of the rca out, then I used an angled pick and pulled the casing out.. Didn't hit the sides of the input at all.. Crisis averted.
Ronisonce
Ronisonce
Woburn, Ma
Ronisonce
