Bridging
Probably not. Depends on what subs and amp you're using. I'll assume the amp is the standard 2 ohms stereo stable and 4 ohms bridged.
If the subs are 4 ohms a piece then you can't gain anything by bridging to run them both because you'd have to wire them at 8 ohms which will give you the same power to each as running them on independent channels. And if you wire them parallel at 2 ohms you'd overheat the amp.
the answer is yes and no. if ur amp can handle the ohm load at what it would be bridged, then yes it will put out more power. but if ur amp cant handle the ohm load then u just cant do it at all.
You could bridge it, but since it sounds like you're running them at 2 ohms stereo they're already getting optimal power from the amp - 2 ohm stereo and 4 ohm mono will give you the same power per speaker.
Twista
Twista
USA
n2audio
