Bridging an amp to 4 Ohms, true or false u get less power than it is rated?
Fr0sty51
Im a bit fuzzy on the whole bridging an amp and making it 4 ohms. I hear so many people telling me that it isn't going to be as much power as the box says. So for example lets take the Rockford Fosgate 501s which if you bridge it goes to 500 RMS at a 4 ohm load. How much considerably less the power are we talking since its bridged. Is it in reality gonna be 475 RMS? 450, 400 what? Someone give me some general ideas of how much it would acutally be. And dont just say just because its a rockford its gonna be so much, thats just an example im talking about all amps in general. The 501s was just an example.
There's no cut and dry answer to that. Some companies lie about ratings, some don't. Bridging makes no difference in how honest the ratings are.
That amp does not have the RCA summing feature. You will have to use RCA splitters at the amp. If you already have that, then check the gains.
Bridging the amplifier Mono(LPF)on that sub will work just fine @4ohms
There’s a typo that looks like 22, meant to be just 2. Thanks for any clues.
T-taps wiggle loose and give static when they do. Posi-taps are too fancy. I just peel a bit with a wire stripper and wrap the splice on that...
Very Nice!!! STEALTH!! I started to say. Plywood would be ideal for a solid amp rack. Just any type of moisture for MDF and it crumbles /becomes...
7
103
Fr0sty51
Fr0sty51
New Jack City
maylar
vlusardi
    Jul 27, 2024
Bobbytwonames
    Jul 26, 2024
