frankiebones
ok, i have the morel hybrid ovation 6 in the front. i am only using 2 of the 4 channels to power it bc i wanted the speakers to break in nicely for awhile before i either bridged or upgraded the amp...
thanks to some advice from our hall monitor ngsm13, i have decided to bridge my amp. did i say hall monitor? i meant hard-working moderator...bring it on my mid-western friend....
what had concerned me prior to this is that the rms rating of the components is far less than the output of the amp when bridged. however, i am going to describe what i would normally do using a DMM to set gains, and then, without a doubt, you guys will tell me how this is incorrect, thus saving my equipment from myself.
everyone who has morels has said that they need above and beyond the rms rating if run passive but it doesnt mean i am going to risk my only source of headbanging during my last year of law school finals.
got all the bullsh*t behind us (can u tell i have ADD?), lets look at the specs, my calculations, and the assumptions i made in inputing values into those calculations.
the morel hybrid ovation 6:
Nominal Impedance 4 Ohm
Power Handling 160W
Max. Transient Power Handling 600W
for the sake of being thorough, here are the specs for the individual drivers:
WOOFER:
Power Handling 160W
Morel Tweeter:
Impedance 4 Ohm
Power Handling 110W
Max. Transient Power Handling 300W
Kicker KX650.4
RMS Power in Watts, All Channels Driven
@ 14.4V, 4Ω Stereo,
@ 2Ω Stereo,
@ 4Ω Mono,
@ 12.5V, 4Ω Stereo, 0.085% THD+N 4 x 70
@ 2Ω Stereo, 0.5% THD+N 4 x 135
@ 4Ω Mono, 0.5% THD+N 2 x 250
Both from using the voltage meter on my head unit, and using a quality DMM to test what the actual voltage is at the amp, i almost always get 13.5V on average, with the many peaks and valleys in voltage to be expected from electrical components turning on and off throughout the car.
i spoke to someone at kicker, and in between the output ratings they gave for 12.5V and 14.4V, the increase in the amp's wattage increases at a steady rate.
therefore, if i wanted to use the most accurate measurement of my voltage, i would use its output at 13.5V, which is basically the average of the 2, (250 + 325)/2 = 287.5W x 2 @ 13.5V, 4Ω Mono.
multiplying this by the impedence and taking the square root of the resulting value gives us the voltage to shoot for as 33.91.
using the unrealistic output @ 14.4V, i would get a value of over 36 to use when putting the DMM to gain control duty.
while i have seen 14V, i would guess its better to undershoot the max unclipped output until i get my hands on an oscope.
HOWEVER, that still leaves us with the little problem that our equation did nothing to take into account the fact that the speakers are not technically rated to handle that much, although people have sworn up and down that they can.
should i use the 12.5V output for starters?
Power Handling 160W
WOOFER:
Power Handling 160W
Morel Tweeter:
Impedance 4 Ohm
Power Handling 110W
Kicker KX650.4
@ 14.4V, 4Ω Stereo,
@ 2Ω Stereo,
@ 4Ω Mono,
