brideing
the amp is internally bridged... there is just 2 positive and negative outputs to make it easier to hook up multiple subs.
i had a directed 1100d and it was like that, dont worry, i was confused at first too:D
just wire it up like you're wiring a normal mono amp, except now you can put each sub on its own terminal, it makes it alot easier, theres no twisting of wires involved and all that nonsence.
Good luck!
Joe.
i want it to run at 2 ohm because it isnt .5ohm stable i have 2 dual voice coil 2 ohm subs each sub would be running at 4 ohm then connected together for 2 ohm so basically if i connect 1 sub to 1 channel and the other sub to the next channel it will be at 2 ohm getting full power out of the amp
Rasheedhos
ny
Rasheedhos
Mike Mccabe
