Sold Brand X 4 channel FS
Johnny Law.Lulz
Banned
Rating: 78.6%
11 3 0
Brand X 4 channel. Comes with manual and remote bass knob. A few cosmetic flaws which are pictured. They are just scratches. Works pretty good actually. Defiantly not an audison but its better than a lot of things. This was a temp amp for my E8's when i broke my SAE-1200d. Im thinking $80 + shipping is pretty good. might be able to get it in a flat rate. If you buy you can have those splitters. Also one screw is missing on a plastic beauty piece that covers the gain setting knobs.
Four channel 740-watt Mosfet amplifier
Four channel, 105 watts at 4 ohm
Four channel, 185watts at 2 ohm
Two channel, 370watts idged at 4 ohm
Hi pass crossover 40 Hz-4 kHz at 12 db (channel 1,2,3,4)
Low pass crossover 40-400 Hz at 12 db
Subsonic filter 27 Hz
Variable bass boost at 45 Hz, 18 db
Discrete class ab Mosfet mobile audio amplifier
Top-mounted fully-adjustable Linkwitz Riley crossover network
Full range pass thru line outputs
0/4 gauge billet style machined high current power and speaker terminal block
Wired bass remote control
Heavy-duty power aluminum heat sink
Power and protection led indicators
Soft turn-on/turn-off
Two 20-amp maxi fuses
Johnny Law.Lulz
Banned
Johnny Law.Lulz
Virginia
Johnny Law.Lulz
