Brahma HT
IamDeMan
Banned
I plan on making a HT sub using a 15" Brahma D2. I will be wiring the VC's in series for a 4ohm load. I want this sub to be best suited for movies, period! For now it will be powered by a sony 250 watt plate amp, but I will replace it down the road with a 500 watt plate. I have never designed or built a home sub enclosure and wanted oppinions on the type of box and size and tuning of it. Any recomendation/suggestions are aprreciated.
Your Brahma will work very well off low power in the HT environment, just a few things to keep in mind.
A larger sealed or ported enclosure will allow you to increase efficiency - it will also increase low end response. I would go with a low tuned ported box, tuned around 22-25Hz, and build it on the larger side of the recommended (talk to Adire or a member on here that designs boxes about enclosure specs).
So do you think I would even have a need for or see a benefit from using a 500 watt plate amp? If so then I would just stick with this 250 watt SONY plate.
I was thinking a large low tuned vented enclosure would be in order. Similiar to what some people do with Shivas and Sonotube(at least in terms of volume and tuning). When I played with WinISD it showed a 9CUft enclosure tuned at 19hz to be the optimum in its thinking. I have read enough here to see that the program can't be trusted entirely though. This is why I was looking for input from people with real world experience on this sub. I may see if someone wants to work out the plans for this beast.
Thanks for the reponse.
EDIT: I also meant to ask if this sub is well suited to be a downfiring sub?
i would advise against downfiring the brahma, but i've never done it so it may surprise you. i would still upgrade to the 500 watt amp as you may want to continue onto greater things in the future.
Thanks for the explanation. I knew there was some way of telling whether a driver was acceptable for downfiring or not, just didn't know exactly how to tell. This is great info.
I suggest you go infinate baffle.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Really, though...low-tuned ported with liberal amounts of volume, and go for the 500W amp...just in case.
I prefer Crown, or QSC. I built an auditorium system with Crown 500's.(I think) it been about 8 years ago. They were pushing the Dual 15" JBL Pro Audio woofers. The depth was so amazing. Tuned way low, however; there was a lot more room displacement. I am rambling, goodbye.
What kind of space? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Feeling insane? 300L tuned to 16Hz should feed that insanity.
250 watts will be plenty sufficient.
IamDeMan
Banned
IamDeMan
/dev/null
kotec123
