brahma 10's 0r 12's....
ktmchaz159
Motocrosskid159
Hey guys... WEll i tell you what, I was on a kicker kick, Dead set on the L7's, Now i'm for the brahmas. i'm goin all out. Spending all the money //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif. Sooo this is what i have to work with, I have a Rockford Fosgate X7 amp 1200 watt @ 2 ohm, but all of the brahmas have the same power handling. But they are goin in an Ext Cab z71. I'm pretty creative when it comes to boxes. The box i am starting to make is gonna fit UNDER the back seat, which allows almost 4.5 cubes or so. SOO Which would fit me better, 2 10's? or 2 12's?... hummmmmm
thanks.
Is the box ported or sealed? What are the dimensions?
Hmm...well, with the limited power you have; if you were going sealed, I'd probably get 2 12's (assuming they fit) and put them in a larger sized box (~1-1.5cuft each), if ported, I'd probably go with the 10's and again put them in a larger sized box.
It will be a ported box, and yes, the 12's will fit, i have had two 12's sealed for a while, and i wanted to go bigger, so i said Brahma. I've been thinking 10's aswell
ktmchaz159
Motocrosskid159
ktmchaz159
mississippi
ktmchaz159
