this is true, but when i use screws i get the wood tighter than i can get it when nailing. Its like a super tight bond instead of just a loose one.Only issue I've ever had using a brad nailer is long panels that are warped as they won't pull the wood in tight enough. Otherwise for smaller boxes they are 100x faster then screw & glue, and it's the glue that holds the box together, not the brads or screws...
So basically, drilling out a hole the size of the head? Is only cosmetic?counter sink so the head of the screw is actually hidden in the wood. You can buy a bit to do this. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
exactly why i want a good wood to wood contact...which i will never trust nails/brads to do.Only issue I've ever had using a brad nailer is long panels that are warped as they won't pull the wood in tight enough. Otherwise for smaller boxes they are 100x faster then screw & glue, and it's the glue that holds the box together, not the brads or screws...
