bp1200.1 on a XXX18
ok put the 18 in a 10 cube box...tune it to 29 hz...and have pushed with at least 1200watts..and u should be fluckin chit up...u should be hittin at leats 140db's from 26 to 32hz..i garantee it
80
****, the amps are at a great price.
Whats refurbished?
This going into a Lincoln LS. trunck space 13 cubes. I was gonna take out the back seat anyways and get two 18's each in a 10 cu box, but XXX out of stock and im low on cash
I still dont understand how a viper 1200.1 is better than a bp1200.1. Its underratted. So is the JBL. 200 extra watts might not really make a difference to the ear. Maybe it will on an 18. Just some one clear this up cause im going crazy. I wanna hook this up
jbl is rated at 1 ohm, your chances of frying your amp is quite high, cuz the xxx requires some power, 1200.1 is underrated cuz they rate their amps at 12volts when a car usually puts out 14.4, so the viper might be pushing 1400 give or take................
wow..two 18's in a linc ls....wow.......u really was bass..why dont u just build a wall and call it a day...use your trunk 4 amps and batts...imo
80
if u still want some to utilize the trunk space..let me know i'll whip up a design but u have 2 get someone to build it.
Don't listen to them...they're on crack. Use you current amplifier, drop the XXX in 10 cubes NET @30hz and you'll be happy. Just mkae sure you don't crack the gains, and makes sure you have the proper fuse to the amp. You shoul dhave the big-three upgraded...and you should look into upgrading you're stock battery.
NG
What are you doing???
sorry bout that. BoominBeast is my bro. I go into his account sometimes. //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif I accidentally posted under his name when i wanted to post under mine. i dont know how to delete the posts so i just did that. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
NG
Alright so, a BP if Fine. Im acctually building a 10^3 enclosure tuned to 28. People are saying its too big. People seem to forget its a XXX18, not a 12. Totally different
Yeah that will be perfect. You probably wont be running it with the gain maxed out so the amp should run fine. They are known to get toasty so make sure it has plenty of air flow.
Good luck and remember the pics //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
alum10
alum10
lotas
