boston pro60 & kicker 850.4??
would this be a good match for the boston pro 60s?
boston pro 60s are a 3 ohm speaker, with the tweeter being 8 ohms
The kicker is a 215watts at 2ohms and 175watts at 4 ohms and 425watts at mono 4 ohm. would this be a good amp for these speakers what would i bridge them to get the 425 watts? thanks
In order to get the most useful responses to questions on the forum, two things must happen.
1) Post in the correct section.
2) Post in a section in which members can actually respond to threads.
If you had read the Announcement, Read FIRST! Product Reviews ONLY in this forum!, at the top of the subforum you originally posted in or the description of that section on the mainpage you would have realized that section is for reviews only. Likewise, members can not respond to threads started in that section. Only the original poster can respond to threads they start in that section.
Moving on to your question; That amplifier would be fine for those speakers. I'm not clear what your asking with the statement "what would i bridge them to get the 425 watts?". Are you asking if you should bridge the amplifier?
You could bridge the amplifier to the speakers to obtain 425w x 2 to the speakers. But you would have to be very careful with the gain and volume knob as improperly setting the gain or getting excessive with the volume depending on how the gain is set could very easily damage the speakers. But with proper settings that setup could be quite effective.
shiftinto5thgea
shiftinto5thgea
california
squeak9798
