boston pro 60s
txred0810
Overall i've never owned a better sounding speaker. I'm pushin these with a PG x200.2 which is pumpin around 245 per side according to the birth sheet. They take the power beautifully and could probably take almost twice that. The only thing i'm a lil dissapointed in is some lacking midbass. I have some Raamat on the way hoping it will make a good improvement in that area. Will deadener make that much of a drastic improvement in midbass?? should i reconsider gettting an amp that will push 300-400x2 to these puppies?? I have them highpassed on my amp at 80hz. These are installed in the doors of my reg cab f-150 mounted with a custom 1/2in MDF baffle.
Mess around with about 3-4 dB of boost between say... 100hz and 200hz -- fool around with it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif should add some kick to the midbass -- strong midbass vs relaxed midbass -- its surprising how easy it is to fix with a little EQ... //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Damping + EQ would be more important than say... getting more power to them... -- nothing wrong with giving them 300-400 watts though haha //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif if you can do all 3 -- why not
Only things that one can't fix with EQ... sloppy performance -- harmonic distortion -- low xmax :p -- as for the 'sound'... thats mostly in the FR... which EQ is nice for...
Damping will help with some of the harmonic distortion down low -- IMD -- and ermn -- clean up some slop a bit... I NEED to do this on my car... more for the rattles in the doors from all the pressure being generated -- than anything haha...
Not to sound dumb or anything but how would i go about doing that?? The bass boost on the amp?? Head unit settings?? I believe my head unit has a midbass Q that will boost certain frequencies...could this be it??
Hopefully your head unit should have some sort of primative EQ //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif that would work just fine... -- what is your head unit?
Kenwood Excelon 579...I just went and messed with it a lil bit and already got some punchy midbass coming out. Amazing what a lil slap to the head will do sometimes. Thanks Ology! I believe the lowest it will let me EQ on the midbass is 500 hz though.
Find a decent cheap EQ that has atleast 1 band/octive -- that way you can mess with ~100hz and ~200hz... if you lower the Q of the EQ on your head unit it may help some more... -- not to mention you can tailor the 'sound' to your likings in the midrange //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Ology has a habbit of being able to make just about anyone feel stupid //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif does it to me all the time
txred0810
txred0810
Huntsville, TX
Eugenics
