boston acoustics pro
yes you can bi amp those comps.
one piece of advice. im running a 300x2 @ 4 ohm amp to them (gains set to give 300 @ 3 ohms to each side). IMHO, you will need quite a bit more than 125w to see potential out of these comps. they are power hungry.
ill be giving each tweet and each mid. 167wts ,at least thats what my amp birthsheet says.and if theses comps are 3ohm .my amp produce more on the the lower ohm load.think its enuff?
just gotta try bro. i would send as much clean power as you can to be honest with you.
whatever power you got, just set your gains using a -3db 1khz test tone and youll be set.
BIGTOSH
BIGTOSH
ric,va
GoochJuice
