Boost it
It dirties the signal. If your gain is set with a dmm then you set the bass boost you have changed your setting. Bass boost is a junk feature that is easily eliminated with an eq that has a fadable subwoofer output.
so basically i can get as much bass as using just the gain and boost off as with the gain and boost. but using the gain alone is a lot safer because of more accurate settings??
You got it. Use the gain and a dmm to set the amp and you keep it clean on most everything you play. If you need more output, try a different box or a bigger amp.
iammenotyou
iammenotyou
cali
iammenotyou
