titanle
Can this stuff be used if there are slight gaps between where the 2 pieces of mdf join? I just glued the back bottom and sides together and im letting them cure. Once its hardened up im gonna use some brad nails to hold them securely and then I'll drill the pilot holes and use proper wood screws.
For the gaps, can i use this fibreglas filler? Is that ok?
