Link?For the same price as good bolts you can buy proper binding posts on eBay that are way more conductive and made of brass
It would be a waste to do this to improve voltage transfer and then put a restriction on it by using subpar materials, I can post a link if needed and they are at ur door in 3-4 days cuz its a us seller
Plus the binding posts step up the appearance alot
The ones I just bought and currently use can fit 8 gauge wire which is plenty as ur terminals or leads on ur sub's are the same or smaller
I was actually looking for bolts as well. Is this a complete 4pc set? Like 2 complete positives and 2 complete negatives?New Amp PCB Type Binding Post Banana Jack 24K 025021 USA Best Quality Deal 4pcs | eBay
I used all four studs, one pos stud goes to sub one pos terminals, the other pos stud goes to sub two pos terminals, same as neg one stud per sub
I used 8 gauge wire from each terminal on the sub to the stud, so on each of the four studs inside the box you have 2 ring terminals, on the outside you have four terminals so with using jumpers you can wire up or down,
Not to clear but do you get it?
Yes it is two pos and two neg complete I love them you can connect bare wire or ring terminals or banana plug/bullet connectors to the outside and ring terminals on the insideI was actually looking for bolts as well. Is this a complete 4pc set? Like 2 complete positives and 2 complete negatives?
Awesome thanks! I purchased some from that link. It says ill get them monday. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifYes it is two pos and two neg complete I love them you can connect bare wire or ring terminals or banana plug/bullet connectors to the outside and ring terminals on the inside
