Sold Bnib Zapco Reference 1100.1 Cheap!!!
trunks9_us
I thought i was going to use it but i need money for a root canal and a crown now which is like 2200 dollars so i need to sell this to pay for that is also comes with a bass boost volume controller over 50 dollars value! I am asking 475 shipped. Pm me your email address for pics it comes with orignal box birth sheet manuals ect. Remember now zapco is a well respected company and put out good clean power. I have tested the amp to make sure it works so i am making sure its not doa.
Single-Channel Class A/B Amp with Crossover EHV Output Circuitry and Dynamic Bass Port Control
-Single channel mono amplifier class A/B for maximum system design flexibility for sub-woofer or mid/highs applications
-SymbiLink™ Balanced Input
-E.H.V. high voltage output circuitry
-Heavy duty, high current terminal blocks
-Compact chassis design
-2 ohm mono stable
-12 dB variable bass port control
-High Current Bi-Polar output devices
-Optically isolated MOSFET power supply
-Sub-sonic filter for sub-woofer protection
-Switch for use as single L ch. or R ch. bridge
-L+R sum mono for use as a bass amp
-Cooling fan allows any mounting position
-Four layer PC board with heavy 2 oz copper
-Surface mount technology w/1% resistors
precision caps, and massive ground planes
Mono, 4 ohms:
Mono, 2 ohms:
T.H.D. + Noise:
S/N Ratio:
Slew Rate:
Damping Factor:
Dimensions:
1 x 800 Watts
1 x 1100 Watts
>95dB
>40V/uS
>250 @ 4 ohms
23"L x7.5"W x 2"H
Suggested Retail $1313.00
trunks9_us
trunks9_us
college station tx
trunks9_us
